Thunderbird won't download messages: "An error occurred with the POP3 mail server. Mail server pop.infomagic.net responded""
  • 3 views
  • Last reply by Toad-Hall
With latest update, Thunderbird doesn't download messages, give the error message above. Sending email gives message: "An error occurred while sending mail: the mail server sent an incorrect greeting: Cannot connect to SMTP server 104.18.37.65 (104.18.37.65:587) Connect error 10060
Do you use Avast Anti-virus Program?
If yes:
Disable the "mail shield" in Avast. If this works, it may be worth trying to leave just the SSL scanning turned off.
